CruMember wrote: Sat 24th Mar 2018 03:57 pmHoi Chillaz!Hashsmoker wrote: Wed 3rd May 2017 01:41 pm Het is koud: It's cold.
But: "het is aan de koude kant" this sentence means it is a little bit cold/chill/not warm.
So you want to add an e:
De koude kant.
It should be like this:
The adjective (e.g. 'prachtig') would only be without an 'e' at the end
in case you are dealing on a "het"-woord substantive (a neuter/neutrum e.g. 'het weer' = the weather)
in combination with an indefinite article ('een'): 'een prachtig weer'.
But with an definite article ('het' or 'de') it would be 'het prachtige weer'.
Note1: all diminutive form words are "het"-words ('de joint' -> 'het jointje', 'het weer' -> 'het weertje' ...) and are also in danger to be used in combi with adjectives zonder 'e'!![]()
Note2: if 'prachtig' would be used as an adverb instead, it's always without 'e' ('het weertje is prachtig!', 'de zomer is mooi' ...)
..."Het is een mooie taal!"Haha!
De Koude Kant
- ed the head
- Location: New Amsterdam of my mind and of my making. Trips:3, Haj:14
Re: De Koud Kant
- Fat_old_dwarf
Re: De Koud Kant
That's a predicative adjective, not an adverb.ed the head wrote: Mon 26th Mar 2018 11:12 am Note2: if 'prachtig' would be used as an adverb instead, it's always without 'e' ('het weertje is prachtig!', 'de zomer is mooi' ...)
- Nuggz
Re: De Koud Kant
That's correctFat_old_dwarf wrote: Sat 26th May 2018 11:27 amThat's a predicative adjective, not an adverb.ed the head wrote: Mon 26th Mar 2018 11:12 am Note2: if 'prachtig' would be used as an adverb instead, it's always without 'e' ('het weertje is prachtig!', 'de zomer is mooi' ...)
- ed the head
CruMember
Re: De Koud Kant
Inderdaad! Wat prachtig!DeLekkersteNUGS16 wrote: Sat 26th May 2018 11:58 amThat's correctFat_old_dwarf wrote: Sat 26th May 2018 11:27 amThat's a predicative adjective, not an adverb.ed the head wrote: Mon 26th Mar 2018 11:12 am Note2: if 'prachtig' would be used as an adverb instead, it's always without 'e' ('het weertje is prachtig!', 'de zomer is mooi' ...)
