Humidity is at 54%. I haven't even begun to research what it should be yet.
I asked about a root stimulator at the grow shop and they game me a 1 oz sample of
Great White.
Instructions they gave me say to use 3oz of solution in a 4" container, 5oz in a 1 gallon container and 32oz of solution in a 5 gallon container. Of course, now it occurs to me that they are assuming that you are starting in a small container and transplanting as you go, and I'm starting in 3 gallon pots and not transplanting then into anything larger.
I ended up making 1 gallon of solution and split it evenly into my 9 plants, about 14 ounces each. I realize now that it was probably too much, but it was only half a teaspoon of powder into a gallon of water. I guess I will see if doing this without thinking will have an effect.
If nothing bad happens, I am considering following the directions - to use once every 2 weeks, stop using 5 weeks before harvest. Maybe half as much next time? If I use it at the same strength I did today, I should have enoungh to last for this grow.
