please help
- Dambuster
please help
I have just purchased a 600w hps with the adjust a wings, i have to wire the light socket up but the socket contains 2 openings (for wires) but there are 3 on the cable. anybody no where the third wire goes??
Trips to Dam: 11/08 - 06/09 - 11/10
DuhhaN
- Dambuster
I have already screwed in 2 wires but there is a 3rd but no where to screw it in?
http://img150.imageshack.us/gal.php?g=dsc00123zlm.jpg
- Boner
Thats really weird, sorry but I really cant help as I dont want to be the reason you blow yourself up
maybe drop them a question via the official site: http://www.adjustawings.com/index.htm
- hulldj
- hulldj
Just had a look on google and found a little information
However, This information may be incorrect for your country.. This needs checking before you do anything. I would also advise you seek professional advice before wiring and plugging anything in.
http://www.uk420.com/boards/lofiversion ... 72938.html
On your E40 or lamp holder socket as shown below there you will have to see which terminal (1 or 2) is for your centre pin and which is for the outer.
Which would mean that your Blue wire goes to the outer and your brown wire goes to the inner centre. This would mean that you remove the Yellow/Green wire from the terminal you have it in below.
The Yellow/green one will go onto your hood to earth it. Not sure where the earth wire is meant to go on your adjustawings hood tho.
I'm guessing that the other end of you cable is going into your ballast using an IEC/Euro plug/kettle plug looking like this -
Or it may have a notch out of it like this one
This last one is for higher temperatures.
Jeeez.... just heard Michael Jackson has died!!
These Euro plug must also be wired correctly. if not moulded to your cable and pre wired... Live to the L terminal, Neutral to the N terminal and the earth to the E terminal.
I would also like to add that if you have an excess of cabling i.e. from hood to ballast, DO NOT coil the cable up to try and make it tidy. Coiling cable can melt and cause fires as the coil acts as a heating element (correct me guy/girls if I'm wrong here). Better to have the cables the correct length. But NO Coiling of your excess cabling.
Does your ballast have a pre wired plug for you to plug into the wall??
The above information has only been given due to the way I saw the E40 socket wired with Brown and Yellow/Green wires into the fitting and the Blue hanging loose. I also would like to mention that I am in no way qualified to even wire a plug. I would advise that you seek help from someone who is qualified in electrical installations as I would not like to see you burn your house down.
Just to reiterate --
And again
And again
Dambuster wrote:the ballast is all wired up, its the socket that you screw the bulb into that needs wiring so it can be plugged into the ballast.
I doubt it is a real Ajust as that part is pre wired and incased in metal to avoid tampering.
hulldj pics explain it perfectly.
When i have my new camera i will drop a pic in here of one of my ajustas to show what i mean.
- hulldj
