Making canna-butter for cooking with marijuana (Cannabis recipe)
- Papi
Re: Making canna-butter for cooking with marijuana (Cannabis recipe)
What about decarbing it first in the oven?
- Papi
Do you do the same when you try to make cannabutter using hash? I mean the decarb in the oven part.
- Papi
I just thought about it, and figured out that i've made my hash chocolate milk when i was younger and all i needed to do was infuse it with some butter/oil and it worked perfectly, so i'm gonna try the same method but simmer it at a low heat with butter and make it like normal cannabutter. My friend who made shitload of brownies told me it's the best and quickest way, i just need to dissolve hash into butter really slowly.
- Papi
I've got some dark afghan oily one, most of the hash gets decarbed during the process of making it, so mixing it long enough with butter should be enough.
- Lemming
- Site Admin
When I've made cannabutter I haven't bothered with the cheesecloth. Simply put the cooked mixture of grass, water and butter in the fridge. Once cooled I had a slab of infused butter floating on top of water and plant material. I then simply lifted off the slab of butter.
