Cannabis Terpenes
monster420
Cannabis Terpenes
Post by monster420 »
Cannabis Terpenes
Each marijuana plant coming from seed has a cannabinoid profile, unique taste and olfactory molecules,
which are not found in the same way in any other plant.
This combination of possibilities creates countless variations in the flavours and effects of marijuana,
and are highly valued by growers, who can discover new emotions when growing different strains,
or may start breeding projects in order to select the plant that best suits their needs or priorities.
The wide range of flavours and effects offered by the different strains of marijuana also helps you to
avoid developing tolerance to its effects: when you have a single variety,
the user and his or her body will develop a resistance – tolerance – to the properties of the plant consumed.
Terpenes are a major component of the so-called essential oils from plants.
Aromatherapy uses the medicinal properties of these terpenes to regulate mood, sleep problems, acuity and overall health.
For example, the essential oil from lavender is calming and relaxing,
while rosemary increases concentration and produces a feeling of well being.
Myrcene:
Myrcene is the most common terpene in marijuana strains (up to 60% of the essential oils of certain varieties)
however, it is not found in hemp textiles. It is also found in large quantities in hops
or in theWest Indian wood (Saint Thomas Bay).
Its smell is very similar to cloves (girofle). Myrcene is a potent analgesic, anti-inflammatory and antibiotic.
It blocks the action of cytochrome, aflatoxin B, and other pro-mutagenic carcinogens. It also has a relaxing, calming,
anti spasmodic and sedative effect. Acting in synergy with THC, myrcene increases its psychoactive potential.
Limonene:
Limonene is often the second, third or fourth terpene found in cannabis resin. This family of terpenes produces the typical smell we all recognise as citrus. Limonene has anti fungal and anti bacterial properties and is also anticarcinogenic.
It prevents the detioration of the RAS gene, one of the factors that contribute to the development of tumors.
It also protects against Aspergillus and carcinogens present in smoke. Limonene quickly and easily penetrates the blood-brain barrier, which increases systolic pressure. During testing on the effects of limonene, participants experienced an increase in attention, mental focus, well-being and even sex drive.
Limonene is used sometimes in spray form, to treat depression and anxiety.
It also has the effect of reducing the unpleasantness of gastric acid and stimulates the immune system.
Plants use limonenes to ward off predators; for example, it repells flies like any insecticide.
Caryophyllene:
Caryophyllene can be found in various herbs and spices, particularly in black pepper, which contributes to the spicy flavour.
It is a local anti inflammatory and analgesic, and one of the active ingredients of the clove (Giroflé).
It is anefficient remedy to relieve toothache. It also has anti fungal properties.
This terpene has the particularity of selectively activate the cannabinoid 2 receptors (CB2), while it is not a cannabinoid.
This discovery opens the door to many possibilities in medicinal research.
Pinene:
Pinene is responsible for the familiar smell associated with pine and fir trees, and to be more precise, its resin. It is the main ingredient of the essence of turpentine. It is present also in many plants such as Sage or Rosemary. Pinene is used in medicine as an expectorant, bronchodilator, anti inflammatory and local antiseptic. It also crosses the hemato encaphalic barrier very easily, where it acts as an inhibitor of acetylcolynesterasics, preventing the destruction of molecules responsible for the transmission of information, which results in memory improvement is largely due to the presence of pinenes that Rosemary and Sage have been considered to be beneficial plants during thousands of years of traditional medicine.
This terpene ca, in part, counteract the effects of THC, which leads to a decrease in the acetylcholine levels.
The result is that the memory fails more with pure THC than with THC mixed with pinene. Skunk strains are, for example, recognised for their high levels of pinenes.
Because this produces a bronco dilator effect, the smoke of plants rich in pinene give the sensation of sucking more air,
which can cause hyperventilation or sometimes cough.
Pinene also improves concentration, personal satisfaction and energy, but it may be limited by the effects of the terpinol.
Terpineol:
Terpineol smells of lilac, crabapple blossoms and lime blossoms.
During tests on mice, their mobility was reduced to 45%.
This explains the sedative effect of some marijuana strains.
Terpineol is often found in strains that have a high level of pinenes, the aromas of which can hide the smell of terpineol.
Borneol:
Borneol has aroma of mint and camphor. It is used in Chinese medicine against fatigue, stress, or to recover from illness.
The Super Silver Haze Marijuana strain from Sensi seeds is known for its camphor aromas,
and its effect is both relaxing and psychedelic.
Hence, we can suppose that it contains a good amount of borneol.
Linalool:
Linalool has a floral smell like lavender and spring flowers. Humans are able to smell it at very low levels, from 1 PPM in air.
Linalool is currently used in the treatment of various cancers.
It also has a powerful calming action, anti anxiety, and produces a sedative effect.
In tests on mice it was discovered that their activity decreased by 75%.
Linalool is thus partly responsible for the sedative effects of certain marijuana strains.
It also has analgesic and anti-epileptic properties.
Eucalyptol:
Eucalyptol (also called 1,8-cineol) is the main ingredient of eucalyptus essential oil.
minty smell of this tree and is also found in small amounts in marijuana.
Its effects relieve pain and improve concentration and inner balance.
Plants containing eucalyptol enhance meditation and concentration.
Nerolidol:
Nerolidol, with woody and fresh bark aromas, can be found in ginger, niaouli and citronella.
It has anti fungal, anti leishmaniasis and anti-malarial properties. It also produces a sedative effect.
Other Terpenes:
Other terpenes that can be found in marijuana resin are, for example, phellandrene, phytol, humulene, pulegone, bergamotene, farnesene, D3-carene, elemene, fenchol, aromadendrene, bisabolene, and many more…
We see then that the endless possibilities of terpene profiles are responsible for variations in taste and effects of marijuana.
Some combinations of terpenes can act in synergy (the effects are added),
while others are antagonists (the effects inhibit each other).
Some terpenes increase the assimilation of THC,
while others affect the flow of dopamine and serotonin, two of the main regulators of mood and behavior.
http://blueriverextracts.com/terpenes/
ed the head
Re: Cannabis Terpenes
Post by ed the head »
Heel interesant
Some good info here, didnt know the specifics of most terps, thanks for sharing.
Ice Pick in Skull
Post by Ice Pick in Skull »
Hold your horses there big boy !
Cannabis consumption doesn't cause cancer as there are very very small amounts of terpenes in the flowers, but this is another ball game. The concentration of terpenoids at the levels seen in those Blue River extracts are scary. Tony V of Blue River doesn't share a lot of his science, mostly because I think he doesn't have any.
Blue River Terpenes are also very much in the murky waters of legislation, yes the terpenes are cannabis derived but as they contain no cannibinoids they are not subject to the regular scrutiny of the cannabis regulations. Everyone in the business wants to catch the next new thing, Tony V & few others saw the rosin thing explode and felt they were missing out. Look carefully for the science behind his PRANA line, you wont find anything clinical.
For the moment, I think I will pass, beyond gimmicks. Let see what the long term effects are after some proper testing.
Cheers
IPIS
monster420
CharonTribalDawn
Post by CharonTribalDawn »
I was actually reading recently about a process whereby myrcene was oxidized into a new terpene called hashishene that occurs when hash is made. Does anyone here know anything more about hashishene's terpene profile? They just discovered it in 2014 so maybe there isn't much info out there.
mowie
Post by mowie »
as soon as they have some good "recipes", say goodbye to good, natural weed.
they will grow anything that looks like weed (indica cash crop probably), spray it with terpenes and synthetic cannabinoids.
fun times ahead!
CharonTribalDawn
Growing your own is always an option. It shouldn't be the only option but I'm already slightly wary about smoking anything I didn't grow myself.
