I have used vinegar to lower the Ph of the water I use to water and fertilize my annual flowers
I only use two tablespoons per gallon
Am I hurting the plants is there any danger of a build up of salts in the soil?
A Ph question
- Willjay
A Ph question
www.stopthedrugwar.org
www.mpp.org
www.drugpolicy.org
www.mpp.org
www.drugpolicy.org
- Drugsbunny
Re: A Ph question
If you are using soil then no need to ph the water as the soil act as a natural buffer.
Db
Db
Herb!
Take happiness with the heartache, go through life wearing a smile.
- OneHighMofo
Re: A Ph question
Drugsbunny wrote: Mon 4th Jun 2018 11:01 am If you are using soil then no need to ph the water as the soil act as a natural buffer.
Db
Depends on the varietal in question - Nasturtiums for example do better with a more acidic medium.
Our favourite lady Cannabis Indica (I'm told) tends to do ok in soil without adjustment.
As far as I understand it you won't be in any danger of salt build-up unless you're using bottled nutrients.Willjay wrote: Sat 2nd Jun 2018 12:06 am I have used vinegar to lower the Ph of the water I use to water and fertilize my annual flowers
In fact one technique some growers use is Vinegar and water to help get rid of salt build ups in Hydroponic systems.
- CloudMaster
Re: A Ph question
Nope!Willjay wrote: Sat 2nd Jun 2018 12:06 am I have used vinegar to lower the Ph of the water I use to water and fertilize my annual flowers
Short answer: PH condition your soil and not your water, stop watering annuals unless you live in a drought zone, they will seek out their own water source if you let them harden up.
Long answer: PM with some more details about your garden and I will provide specifics (sorry currently busy running a smallholding nursery).
P.S You can grow excellent Quorn mushrooms in hydro buckets if you use vinegar as a PH controller
- Willjay
Re: A Ph question
Thanks DB, OHM and CM for your reply’s
my soil is promix HP and everything is in pots I should of mentioned that maybe
that’s why I fertilize with IONIC just trying to follow directions
They are a delicate flower but have late fall blooms worth the work
www.mpp.org
www.drugpolicy.org
www.mpp.org
www.drugpolicy.org
macky
Re: A Ph question
Annuals bought at a greenhouses are watered with fertilizer added through injector system .
The frets are not near full strength but are feed always ,use miracle grow 20,20,20 every third watering if there in hanging pots.
Planting’s in ground once a week ,ten days I like to hit all my plants day or two after a good flush rain.
Most problems are from acidic soil,the plant can not take up nukes,stay yellow.
Little horticulture lime will fix this ,where your cider shrubs ,trees love acidity add cider mulch your blue spruces and such to keep them happy ...I was married in a big commercial greenhouse
Like everything in moderation is best
- Willjay
Re: A Ph question
Thanks mackymacky wrote: Mon 4th Jun 2018 09:38 pm Annuals bought at a greenhouses are watered with fertilizer added through injector system .
Little horticulture lime will fix this ,where your cider shrubs ,trees love acidity add cider mulch your blue spruces and such to keep them happy ...I was married in a big commercial greenhouse![]()
www.mpp.org
www.drugpolicy.org
www.mpp.org
www.drugpolicy.org
