Old man new iPad questions about TRRS jack
Moderators: Balou, 2rollingstoned
- Willjay
Got a iPad at the beginning of the shutdown, looking into hooking my mic mixer to the iPad using the headphone jack, the question is, does the adaptor jack that they recommend change the stereo single to mono? From what I understand the Tip Ring Ring Shank connector on the iPad is for Right Left speaker and mic, That’s only one audio in, am I missing something?
The goal is socially distancing live music on the Facebook and/or YouTube
www.stopthedrugwar.org
www.mpp.org
www.drugpolicy.org
www.mpp.org
www.drugpolicy.org
- DjShaggy
Re: Old man new iPad questions about TRRS jack
Microphones are always mono
- DjShaggy
https://www.gear4music.com/iPhone-iPad-Interface.html
If your looking to connect a output from a mixer into your iPad with glorious stereo something from the above page may suffice, the mic input on the iPad will not be a very good quality.
- Willjay
That is the problem, mics are mono, and all the products that convert the signals are stereo and I can’t figure out what the “Rode SC4 adaptor” does internally
Planning on running my TouchMix into a “clean Box Pro balanced to unbalanced converter box” then using a “Rode SC4” to connect it to the iPad
Wasn’t my original plan to try and stream shows, but in these times you have to adapt. The area where I live is about to go “yellow” with that standing we could put bands in the gallery and use the Facebook to broadcast it.
Yellow allows business to open to less than 20 people and no touching
Thanks for taking the time to help
www.mpp.org
www.drugpolicy.org
www.mpp.org
www.drugpolicy.org
- Comus
apart from when they are stereo microphones
I'm in shocks and stares
- Comus
hi willjay ... you might need to bear in mind that your line level will need converting down for the ipad to cope .... the set up you have mentioned there with the desk and the DI should work but maybe substitute the DI and sc4 and just run a pair of RCA to TRS from the two rec out -10db sockets on the desk and then get a Headset Buddy cable (https://www.headsetbuddy.com/line-level ... artphones/) to go from the TRS and then into the ipad.Willjay wrote: Tue 12th May 2020 04:55 pm
Thanks for taking the time to help![]()
- DjShaggy
You’ve got me there, they would be 2 mic level channels wouldn’t they?
My experience is more live than studio...
- Willjay
Me too, never was a studio guy, either FOH or in the early days monitor mixDjShaggy wrote: Tue 12th May 2020 06:28 pmYou’ve got me there, they would be 2 mic level channels wouldn’t they?
www.mpp.org
www.drugpolicy.org
www.mpp.org
www.drugpolicy.org
- Willjay
Thanks that just might be the solution I was looking for. Thanks againComus wrote: Tue 12th May 2020 05:41 pmhi willjay ... you might need to bear in mind that your line level will need converting down for the ipad to cope .... the set up you have mentioned there with the desk and the DI should work but maybe substitute the DI and sc4 and just run a pair of RCA to TRS from the two rec out -10db sockets on the desk and then get a Headset Buddy cable (https://www.headsetbuddy.com/line-level ... artphones/) to go from the TRS and then into the ipad.Willjay wrote: Tue 12th May 2020 04:55 pm
www.mpp.org
www.drugpolicy.org
www.mpp.org
www.drugpolicy.org
- Comus
if it works out don't forget to let us know when you plan on broadcasting mate
- Willjay
Just ordered this
[/https://www.headsetbuddy.com/3-5mm-male ... o-adapter/
www.mpp.org
www.drugpolicy.org
www.mpp.org
www.drugpolicy.org
- Willjay
Hoping for June, already have talent booked even have the funds to pay them for the last Wednesday of the month through NovemberComus wrote: Tue 12th May 2020 06:51 pm if it works out don't forget to let us know when you plan on broadcasting mate![]()
I will keep you posted might have more questions,
www.mpp.org
www.drugpolicy.org
www.mpp.org
www.drugpolicy.org
- Comus
excellent ... good luck dude
- Willjay
https://www.facebook.com/Gezellig-LIVE-100159995088174/
This is the page I set up to live stream the Listening Room, a small venue I do sound for once a month. It’s on the last Wednesday of the month at 7:00 pm eastern time.
The nonprofit www.ExchangeArts.org has agreed to pay the performers to play in a closed set Streaming on Facebook. I think I have all the bugs worked out, tune in if you can and let me know what you think.
I’m a old analog stage hand stumbling into the 21st century
www.mpp.org
www.drugpolicy.org
www.mpp.org
www.drugpolicy.org
- hulldj
I'm a bit late to this party but do you have a laptop/pc/mac as well as the ipad?
The next step up may be to start using a program called OBS studios.
Let me know if you would like any further information if you are not already aware of it.
