for how long grass cold be stored ?
dried and pressed?
i have not take the same for more to 5 months and you?
store
- AL
Re: store
for years mate, plus the longer you cure it the better it becomes. store it in a cool dry dark place and can be there indefinatelyga wrote:for how long grass cold be stored ?
dried and pressed?
need a spliff......
fluzzmann
Re: store
I had some weed and it was not so good after four weeks. is it ok to keep the pot for long times? Maybe to freeze the pot is good? I buy much and smoke little so many times my pot is dry with no power.AL wrote:for years mate, plus the longer you cure it the better it becomes. store it in a cool dry dark place and can be there indefinatelyga wrote:for how long grass cold be stored ?
dried and pressed?
i have not take the same for more to 5 months and you?....................................peace........................
"My mother allows me. Thank you mother"
- NirvanaEJ
dont freeze it. i dont know if you can get gladware or tupperware where u live but it works like a charm ive been using it for years. to dry the buds keep them in the container in a cool dry dark place with the lid slightly open, checking on it to make sure u dont overdry and it just crumbles when u touch it. when that is done store it in the container in the same place, lid shut tight, that should keep the buds for a very long time and maybe even make it better, like a fine wine.
EDIT: just read it over, dry buds are not the reason the weed have no power, how do u store it?
fluzzmann
well I have a jar. In the beggining, the pot is very good, but then after 4 weeks it is a grey colour and soft. Then it just make me sleep. I only smoke one time a week. I race road bicycles and too much gives me troubles.NirvanaEJ wrote:dont freeze it. i dont know if you can get gladware or tupperware where u live but it works like a charm ive been using it for years. to dry the buds keep them in the container in a cool dry dark place with the lid slightly open, checking on it to make sure u dont overdry and it just crumbles when u touch it. when that is done store it in the container in the same place, lid shut tight, that should keep the buds for a very long time and maybe even make it better, like a fine wine.
Thank you for all of your posts.
- NirvanaEJ
courtjester
Home canning jars. In the states, the most common brands are Mason or Ball jars. You need a jar with a sealed top -- like a Grolsch. Only bigger.
Cannabis should be stored in glass. Glass doesn't suck up your beloved trichromes. Ever seen all that gunk on the inside of your baggie at the end of a sack? Those are wasted cannabinoids, sucked in by plastic.
