I apologise for the quality of the pictures - the camera on my phone is nowhere near as good as my old (lower resolution) Fuji Finepix2400, but I was topping up one of the tanks and had the phone in my pocket, so...
Welcome to the show.
First up, I'd better give you a quick run-through of the setup.
4 x 424 NFT hydro tables running on GH Flora 3-part nutes under a single light-rail mounted 600W HPS. Extraction is a 150mm RVK with carbon filter.
All but one of the tables are carrying 5 Brothers Grimm Apollo 11 clones - the table in the far right corner has 4 plants on board, so a total of 19 plants - all vegged initially under 250W MH, then 400W HPS on 18/6 light-cycle. Flowered between 15" and 18"... Flowering time for these Sativa dominant beauties is just 49 days, so we've got 2 weeks left before the chop.
This grow was literally thrown together in a hurry - normally I run two tables at a time, but this time I was in need of a slightly higher return, and after finding a light-mover for the right money, I thought I'd give four tables a go running side-by-side with the 600W skimming past the tops less than 18" away. Maximum lumens for the plants with minimum stress caused by heat. Plus, the plants tend to be more uniform as they don't stretch for the light - okay - a couple of the A11's have decided to reach for the sky, but they're out of the main flight-path of that big 600 watter so they seem to be enjoying the altitude without the risks of burning!
Right then - first up we have a group shot...
The colour balance was a bit better on this one than the next - damn that HPS glow!
This is the right hand side corner - you can see that solitary A11 standing tall above the others there...
The left hand side of the group...
On this close up, you can just about see a tiny little bud forming in the middle of the fan leaf - I've only seen this before on a pheno of Killer Apollo I had, which would pretty much bud-up anywhere it could find space! Crazy shit.
I'll try and dig out my proper camera and take some better close-up shots of the resin production on those leaves for y'all, but there we go for now.
Two more weeks and a couple of days of sticky fingers cropping and trimming and we should see the final result!
